Thanks Five Five, this is what I PM'd to Rub
I'm actually having an issue with the caliper, or maybe even the rotor. When I turn the bars to the left at slow speeds like pulling into a gas station it makes a low pitch howling noise. Sounds like when a dump truck is coming to a stop if you have ever heard that sound. I had my mechanic look at it, and he thinks maybe the rotor might be warped a little. There doesn't seem to be any real way to adjust the caliper.
Also you know those buttons that are all the way around the rotor allowing the rotor to move? There are a few of them that have rub marks on them. Not sure if that is a cause of this or not.
Just wondering if you had any issues like this, and again it only seems to happen turned to the left. One thing I noticed, and supposedly it is normal is the fender moves when you turn left or right, have you noticed this as well?
Rub responded with the fact that he had the noise issue, and switched over to ceramic pads, so I will try that as well and see if that fixes it.
