My 2010 Wolf now has just over 5,000 miles on it (I know, I know, I don't get much time to ride it) and sure enough last time I took it out the cam belt snapped. So far, so x-wedge right but the reason I mention it is that everything I ever read told me if you had the easy start cams fitted this wouldn't happen. Well my engine had the 545 easy start cams fitted right out of the factory, I have the build spec from S&S to prove it, so clearly that is not the case. It can happen anyway.
Just a head up to any other Wolf owners out there, seems like even if you fitted the cams the belt will still break. So check those belts.
