BadBrad
2005 Pitbull
The bike? My wife's '03 Mastiff. Looks like the EHC has crapped out, but thought I would share this all the same. A month or so ago, the brake lights and turn signal timers quit working. Bought a used EHC off ebay
. Well, her brake lights and turn signal timers work, but no rear tail lights. :angry: She was better off with what she had before, so I changed it back. Sunday, her headlight went out. :bang: What's strange is that when I pull the headlight off the 3 prong plug, I have power coming from the plug. I click the high beam button and power comes from the side socket.....just like it is supposed to. So, I figured a bad bulb, got it replaced and plugged it in and still no headlight. I pulled the tank and checked continuety on all 3 wires....good! :2thumbs: Did I get a bad bulb? It just so happens that my little Honda Civic has the same plug for its lights. So, I pluged the bike light into the Honda plug.....it works. I go back and plug it into the bike plug......nothing. Using a power meter, I find that power comes to the light socket until I actually plug in the light, then no power. Must be an internal short in the EHC. The good news is that I got in on the group buy with Jake and have a new WP Module on its way for Rocky's bike. We wanted to ride this weekend (her birthday) to the casino in MS, stay overnight and watch a concert. If the WP module doesn't make it here on time, I'll direct wire the lights with a toggle switch.
I just found it strange that I get power to the plug for both low and high beam, but when I actually plug the light into the socket, the power is gone. Is this normal for a failing EHC? I would figure no power at all. :loony:
. Well, her brake lights and turn signal timers work, but no rear tail lights. :angry: She was better off with what she had before, so I changed it back. Sunday, her headlight went out. :bang: What's strange is that when I pull the headlight off the 3 prong plug, I have power coming from the plug. I click the high beam button and power comes from the side socket.....just like it is supposed to. So, I figured a bad bulb, got it replaced and plugged it in and still no headlight. I pulled the tank and checked continuety on all 3 wires....good! :2thumbs: Did I get a bad bulb? It just so happens that my little Honda Civic has the same plug for its lights. So, I pluged the bike light into the Honda plug.....it works. I go back and plug it into the bike plug......nothing. Using a power meter, I find that power comes to the light socket until I actually plug in the light, then no power. Must be an internal short in the EHC. The good news is that I got in on the group buy with Jake and have a new WP Module on its way for Rocky's bike. We wanted to ride this weekend (her birthday) to the casino in MS, stay overnight and watch a concert. If the WP module doesn't make it here on time, I'll direct wire the lights with a toggle switch. I just found it strange that I get power to the plug for both low and high beam, but when I actually plug the light into the socket, the power is gone. Is this normal for a failing EHC? I would figure no power at all. :loony:
