rhinoevans
2002 pitbull. Rode last Sunday in Vegas. Great ride, no issue, parked it, got up Monday for work an nothing. Turn the key and absolutely nothing, no sounds, no needle sweep on the speedo, and no power to anything. Put on charger for the day, and nothing.
Not really had time to start troubleshooting but does any easy check come to mind from anyone. Later tomorrow I plan to get out the voltmeter and start checking volts and power flow. I will chwck battery first, then ground, then what. Ignition switch, since when I turn it I should get something and get nothing,
One last piece, last couple of rides or so. turn key, power on and good neddle sweep from speedo. switch to run, then start and nothing. Recycle switch to run, then start and she fired up. Did this a couple of times before above. Thanks for any help
