bigmax060472
Good afternoon. I bought a 2007 Mastiff. The bike only had 4,000 miles. The clutch was very tight. However, the gears shifted perfectly. It had a 12-plate clutch. I read all the threads about clutches on this forum and decided to install a 9-plate clutch and an Easy PulL clutch. I ordered all the necessary parts and everything was installed successfully. Squeezing the clutch lever has become much easier. BUT! I can’t adjust the clutch. I adjusted the clutch in every way I found on this forum. But the following happens - after a complete adjustment, the gears shift perfectly, the free play of the clutch lever is 1/16. However, as soon as the bike warms up, I ride a maximum of 500-600 meters, the free play of the clutch lever increases very much. About half the lever travel. I adjust only the cable, everything is fine, I ride another 500-600 meters and the free play of the clutch lever is again half the travel. I'm doing a full adjustment again, but the same thing happens again. Does anyone have any ideas on what could be wrong? Thanks in advance!
