Aloha Big Dog Family
BadaBing
Installed gen 1 bike starts BuT left side hand control horn,turn signal and hi beam functions not working
In your location you may want to consider waterproofing ur Dog. A spray can of Marine conformal coating will help with moisture/corrosion issues. Spray every PC board you find. Some heat shrink on ur JST connectors will help as well. Just my thoughts..fwiw.
BadaBing
Good morning mahalo for the help just because the jst plugs is same i flop it right to left and left to right to determine if the board is good sure enough it is the horn button crank the engine and the low beam flash the blinker.
