An easy solution is to take and re-wire the compressor and relief to a SPDT switch with center off.
One position would activate the compressor.
Center would be off
Second position would activate the relief solenoid.
Disconnect both connectors shown
Connect solenoid ground wire.
------------ Compressor
+12v ----FUSE ----- SWITCH
------------ Solenoid
I'd have to dig a little deeper to tell you what A for the fuse but I'd likely start with a 5A unless someone knows more specifically.
An as mentioned, do contact Axel as I think this was something added later on to his modules.
