Snuffy Well-Known Member Supporting Member May 19, 2026 #1 What is the preferred oil for recharging the air filter element? For best performance and color dye.
Shredder Active Member May 19, 2026 #2 I have been using these folks for years, especially when looking for a specific color. Engine Air Filter Cleaner - Green Filter USA Green Filter Cleaner: Specially formulated to clean & re-oil your Green High Performance Air Filter. Protect your engine & maximize airflow. Shop now! greenfilter.com
mleach72 Well-Known Member May 19, 2026 #3 K&N makes a recharge kit that i use. It comes with cleaner and oil. I would imagine that any brand name oil for the cotton type filters would be fine.
Snuffy Well-Known Member Supporting Member May 19, 2026 #4 I have used K&N in the past. Just seeing what options are out there.
SKOGDOG One of the old ones. May 19, 2026 #5 I’ve used K&N too. I read somewhere that Dawn diluted with water was an acceptable cleaner. I always use the spray oil, as I believe any motor oil-type application would be too thick. I could be wrong.
Mr. Wright Knows some things Supporting Member May 19, 2026 #6 What ever you use, lightly spray it on.
