mittens
So are my assumptions correct, giving the gauge power, ground, and the signal coming from the tranny sensor. will work both the speed, and the Odometer (working mileage is useful on gas, and maintenance.)
If I get a guse with other indicators like the dummy lights, what do they hook to? oil for instance. I can find neutral haha But its its as simple as a wire, I may hook that us as well.
Unless all this will need a Brain again.. then its not worth it.
I will also assume if i added turn signals back in, there would be 2 wires for the indicators in the speedo, so that's probably easy IF I did that. But with the bars on it probably not adding switches.
