.600 Cam
judge8000
Im thinking about a .600 Cam, what do the stock 117 springs rate at? And would you go with duel coil or behive springs?
Thanks!
bigdogtech01
Thanks!
You will need to change out springs. A good spring to go with is the Comp setup for .600 lift. But, without cutting cylinders down to bump compression up a little, you will never get full potential out of the .600. A .585 is a better option and heads are setup to handle up to .585 from factory. It's all about how much $$ you want to spend :D
prairiehorse
john sachs did my heads and im using the .600 cam. Works great. Great knowledgeable person. he is a member on here. Give him a call
