.600 cam
Big Dog Mike
I have a 2005 Ridgeback with a 117 and Im thinking of installing a .600 cam. What do I need to replace? Valvesprings,pushrods ect????? I heard the 2005 117 can handle the .600 cam is this true? Thanks for your input Mike
john sachs
You need to check installed height of the springs, and then collapse the spring to .660" starting at the installed eight. If the spring doesn't coil bind at the .660" measurement then you're good to go.
John
