I created a PDF based on Bowhunter's install tutorial. Also added some content from PHATASS & chacha
Hopefully this can be usefull to forum and maybe it will come in handy for myself once day
http://www.abirthdayanywhere.org/bigdog/585-Cam-Install.pdf
This appears to be the exact same thing as was posted already in the how-to section.
One thing missing from this procedure is that when you pull the old cam out, your lifters can fall out. To avoid this, put a rubberband around the lifters on each cylinder and create some sideways tension to allow them to stay in the up position in their respective bore. Remove the rubberbands after the new cam is in place.
Anyone reading this needs to be aware that the adjustment of the pushrods section DID NOT work (for me). I followed it exactly 3 times and each time, I ended up with excessive lifter noise after the engine had warmed up. If you do it this way (as shown in the PDF as well as the HOW To (pdf is the same thing, just ripped off someone elses work IMHO)), you will find that you will have excessive lifter noise. You can have your pushrods end up getting bent because of it.
I strongly suggest that you adjust each pushrod separately and that you find the heel of the cam lobe by using a dial indicator on a magnetic base ($40 from Harbor Freight). Using the dial indicator, it is extremely clear when you are on the heel of each lobe. Yes, you still need to let the lifters bleed down before any rotation. This is a time consuming but easy task.
All I am saying is don't be like a lemming and jump off a cliff just because everyone else has done it. Use some common sense and spend the $40 bucks on the proper tool. You only want to do this one time and have it right, right? And you end up with a new tool that can be used on other things.
It should be a crime to post or repost a "how to" type thing unless you have actually done the procedure yourself. Toodie admitted he has never done this in his post "Hopefully this can be usefull to forum and
maybe it will come in handy for myself once day "
Richard
