4000 trouble free wire + miles, poss dyna2ki prob
Slider
I have an 04 107 chop, wire plus, dyna2ki, Been running great till yesterday. Put dog away hot, tried starting next day, no fire from the coil-nothing to either plug. No power to coil. Checked all fuses, wiring everything seems ok. Both green lights come on the wire + modules when turn on the ignition.
Here's the biggie. The nose cone dyna module LED doesn't flash once when I power it up like it's supposed to, and doesn't flash with the pickup sensor when I crank it. I think it's a bad ignition module, only 5 months old.
Anything else to try before I remove the module to send it back to dynatech for troubleshooting?
Thanks.
lee
could be a bad ground - does that unit have its own ground wire or is it grounded through the mounting of the unit itself to the nose cone? might be worth running a ground wire from the nose cone to the frame and see if that helps
Slider
The ground it ok through the unit.
I emailed tech support at Dynatech. They are usually good at responding.
Keep ya posted.
