2010 BD Bagger Speedo quit working....
bruce
The original or older big dog Speedos we're not LCD they had sweep arm for the speedo I know they had problems with the solder joint at the wires that connected to the circuit board I had to fix mine years ago ( you had to take apart almost the entire Speedo to get inside the box where the circuit board was ) and it's been fine ever since not sure if the LCD Speedos may have a similar issue if it stops working only thing I could suggest would be to take it apart you have nothing to lose because it's not working anyway, even if you end up having to purchase a new one I would take the old one apart, once you understand how something works it's usually pretty easy to fix , PS - remember all posts are worthless without pictures HA HA IMG_20200612_114049350_HDR.jpg
Mastiff Rider64
The original or older big dog Speedos we're not LCD they had sweep arm for the speedo I know they had problems with the solder joint at the wires that connected to the circuit board I had to fix mine years ago ( you had to take apart almost the entire Speedo to get inside the box where the circuit board was ) and it's been fine ever since not sure if the LCD Speedos may have a similar issue if it stops working only thing I could suggest would be to take it apart you have nothing to lose because it's not working anyway, even if you end up having to purchase a new one I would take the old one apart, once you understand how something works it's usually pretty easy to fix , PS - remember all posts are worthless without pictures HA HA View attachment 84597
The 2009 Anniversary Models and I think a few other 2010 models had this speedo in them. Its a dual Analog and digital input speedo. But has all your warning lights built in, low fuel, oil and check engine light. The signals feed from both the ECH or since fuel injected the VFI module. Then the trip has an A and B, you can use it as your tach also with the push of a button. This one has several different things the others didn't but these also are no longer being made. I think the company is still around but not 100 percent on that.
aspen874
If you find a source to buy or repair one I would like to know
