2009 Big Dog Mastiff Exhaust
mbtrade
I have a 2009 Big Dog Mastiff with stock exhaust and I am wanting it to be louder. If I put Vance and Hines 2 into 2's on do I also need the jet kit and what else will I need to order? Also, the pipes that I have seen state that they fit up to 2008 models. Will they still fit 2009?
Thanks
aspen874
there should'nt be any difference between an 08 or 09 as far as the V&H pipes goes, to get the best performance you will have to change the jets, also if you don't like the sound of the 2-2 pipe there are different ways to alter or replace your baffles in the pipes.
There are many threads on here about this, I reccomend you do a search
:hi:welcome:hi: the only thing I didn't like was the mounting bracket on the V&H wasn't chromed. Getter chromed.
mbtrade
Aspen874, I see you have added the 2-2 pipes. What else did you have to do to add them? Just jet it and change the pipes?
aspen874
I didn't like the sound of the baffles that comes with the pipes (personal opinion), I changed to the Big city Thunder baffles and change the jets.
The one thing I strongly reccomend is you rap the rear pipe with heat tape from one inch below the flange done to around six inches and secure it with stainles tie raps to prevent heat damage to your right side cover, the heat shield will still cover it.
I checked mine and they are fine after 10,000 miles, I wonder if you can position the heat sheilds different from one to another? Mine show nothing from heat damage.
aspen874
mine did it and also on a friend of mine's 06 K9. I don't know why some bikes do it and others do not, but when you are installing your pipes this procedure is cheap insurance
vaky12
Banned
hello
To break the monotony of Pandora style products, and to give everyone the right jewelry to suit many occasions without having to shop for every event, Pandora has come up with latest style of collection with replaceable glass beads, bracelets,, etc. All one has to do is replace the removable parts and join it back with the accessory of your choice. And lo! The new look jewelry is all yours.pandora beads wholesale
erldawg
F*#kin spammer dickhead....
