2008 pitbull having starting problems
Chazzz
Ok the pitty is all up and running swt as now it was a circuit breaker that's run off the regulator and is behind where the battery sits while that was replaced we put bigger wires on the positive negative from battery to earth and starter has really improved the starting cheers evry1 thanx for the help
Chazzz
Used the pitty for work yesterday and all is well massive back to cruzn again jus havn it out parked at the shop front of barber shop the attention it gets is unreal I'd love to know if any 1 in nz has a 2008 or later model big dog they seem very rare here in nz there are lots of earlier model dogs but I ain't seen any like mine yet
Chazzz
all is well with the pitbull ended up been a factory relay box had frizzled under the seat near the batt holder replaced that and put huge truck wiring to the batterey from starter and earth and brought new 600cca harley batt brandnew witha new smartcharger have had no problems at all now i did blow over 6bulbs in headlight so brought a anti vibrate bulb and mounted more rubber to the bottom housing of headlight and trees stop all the vibrations hasnt blown since have been on lots of rides
