snake1962
About to service mine for the 1st time, oil drain easy, primary drain easy, tranny not so easy. On my K9 directly under the drain plug are two of the oil lines that feed from the oil tank. There is no way to get to the plug without removing the two oil lines that I can tell. Kinda sucks if you already changed the oil first. It does have a 45 fitting on it, haven't tried to see if I can turn it any for clearance. Help !!!! :bang:
