2007 EFI Fuel Pump
BigDogBro1
Made in the USA
Does anyone know whos fuel pump BDM used in the 07 Bulldog or later bikes. Is it an S&S pump? Mfgr, part numbers and details are what I'm looking for.
Thanks!
BigDogBro1
Made in the USA
Earlier post found from Nomad2day
http://www.bigdogbiker.com/forums/help-wanted/18838-fuel-pump-question-screaming-load.html
I got the pump out. It is a Walbro F20000107 fuel pump.
http://walbro.com/contactus.aspx
Did a search on the web and they seem to run about $108.
Even some lawn mower shops come up in the search saying you can get one.
Neil
__________________
Neil in Tenn
Thanks Neil
Doing some additional searches has uncovered the Victory MC may have also used the same Walbro F20000107 fuel pump. Possibly Arctic Cat as well.....Makes sense, seeing Polaris and Arctic Cat were started by brothers years ago.
Victory Forum...
"Thanks thats good to know and Thanks! I needed a fuel pump but found the OEM for Victory. The pump is made by Walbro part number F20000107 Pressure regulator part# is 135-15. VE Peterson has them for $108 and about 50 for the regulator. V.E. Petersen
"Good to know if someone comes in need of a pump. It was also used on Big dog models and other custom bikes.
Thanks for sharing...is the Pressure regulator also made by Walbro?"
"Yes it is, just came in 5 minutes ago. Both Walbro $155 total."
"I noticed the pressure regulater flows both ways. I originally thought it was a one way valve since mine didn't allow backwards flow. I wonder if my regulator is causing the whole problem?"
"The pump is made by Walbro part number F20000107 Pressure regulator part# is 135-15. VE Peterson has them for $108 and about 50 for the regulator."
"You could also call Rylan at The Vic Shop and he sells rebuilt pumps at a good price. His number is 402-659-9655"
Welcome to the Vic Shop
Fuel Pump Rebuilds
Services
UPDATE 4/21/11 S&S has the fuel pump available for our dogs as well.
This info should help us out with this issue.
JR07
That's good to know that I can always go to the lawn mower shop to get parts
