Jwooky
You have to remove the top motor mount bolt top remove the throttle body cover.
Remove the fuel line from tank. Be prepared with a vacuum cap or piece of 3/16 hose with a bolt in it to cap off tank. Replace the fuel line as many of the old lines break down with ethanol and also gum up the injectors.
Remove the fuel rail screws(seen in pic below). Once the are out, the rail and injectors can be pulled out.
I use a sheet metal screw to remove the injector screens. I recommend to just replace them. A standard fuel injector screen works perfectly.
You can also use carb/injector/brake clean to flush out injector while you have them out. Use a 9v batter to cycle the injector.
