2006mastiff exhaust
mjsk9
Agree awg.... Hmmm...... The only thing I can think of and I don't believe anyone asked.... is your V&H a 2 into 1? My V&H 2 into 2 used the bracket I previously posted so have to think it might be a 2 into 1?
mjsk9
You might have to go to the V&H website and search Big Radius to look at the pipes you have? There are 3 pages and 30 results that come up with that search. click on each one and open the instructions to see a potential bracket fit?
Pictured below is a similar bracket but reversed?
Big r
mjsk9
The big raids are two pipes
No..... they have both see below and why I asked. Have never seen the picture of your bracket for a 2 into 2 for a K9 or Mastiff unless it was modified by the original owner?
mjsk9
The bracket I need is pictured above. Thanks
Like I mentioned, you may want to start at the V&H site, look at every (30) Big Radius exhaust available (2 into 2 and 2 into 1) click on each and click on the pdf instructions to see what bracket is provided. Then talk with the representative to see what MIGHT work.
I am "exhaust"ed, pun intended so I am OUT!!!!!! Good luck!
Scott J
where can I find the correct exhaust bracket for my 2006mastiff. I'm installing a set of Vance and hines big radius and the bracket that came with kit won't fix. I need the flat offset bracket.
