2004 ridgeback speedo
Sellsbooze
My 04 Ridgeback speedo neutral light never goes out? It dims when in gear and gets brighter when placed in neutral? Any ideas or suggestions on this? Also seems frequently it is tough to get into neutral, mainly when I have stopped for a minute then try to place it into neutral.
stlmikie
I wish I had more money.
Getting it in neutral is easy peazy. one is to make sure your clutch is adjusted properly. Two is when you are ready to put it into neutral do it while you are still rolling a bit or to blip the throttle at the same time you shift into neutral. Just a little bit. that usually helps it slide right in. As far as the light I can't help you bud.
awg
I think it may be a bad ground wire some where. I always thought if the ground wires weren't tight it would feed back to the source. I think.
