2004 Primary Removal/Seal Replacements
roadie1389
Greetings
So stator is out in the bike and I need to take the primary apart anyway. The final drive shaft seals are leaking so I am going to replace that but I the transmission is also leaking. Can't tell if it is the shift seal, vent tube or the final drive seal. If it turns out to be the drive seal -
#1 - Can you get the pulley off without taking the Inner Race Bearing off?
#2 - Bike has less than 16k miles, would the IRB be damaged that it has to be replaced?
Also There are 2 Cometic kits for the HD primary 9885 and 9886, ?They are slightly different. Does anybody know exactly which is the one for the BD HD Style primary?
Thanks
