I’m thinking carb needs cleaning maybe something in intermediate jet carb is adjusted right I cleaned air filter put new plugs runs better for a day or so then starts running bad again pull plugs and they are covered in black soot vacuum caps look dry and cracked will try new vacuum caps todaySounds rich or idle is to low causing it to do that which intern with low idle it will become to rich.....needs to idle around a 1000rpm....some people lower the idle to hear the hit of the engine and this will happen cause of that...if thats not the case air fuel mixture screw needs a slight adjustment possibly to correct it
Where do you find these HMAN?New caps will help. Buy the silicone ones. They last a bit longer. And buy extras for the tool roll.
I get mine @ O'Reillys Auto Parts, but thats cause they right around the corner from me...Where do you find these HMAN?
Works for me, i have one down the street also. They just called vacuum caps? Thank you.I get mine @ O'Reillys Auto Parts, but thats cause they right around the corner from me...
Yep, they sometimes come in an assorted sized packs.Works for me, i have one down the street also. They just called vacuum caps? Thank you.
