2004 BIG DOG BULLDOG RECALLS
waykool
Banned
RECALL #1
Recall ID #59557 - STRUCTURE:MOTORCYCLE KICKSTAND/CENTER STAND
Recall Date JAN 25, 2006
Component STRUCTURE:MOTORCYCLE KICKSTAND/CENTER STAND
Motorcycle Affected BULLDOG
Potential Motorcycles Affected 9726 Recall Details
Recall Date
JAN 25, 2006
Motorcycle Affected
Summary
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING MAY STRETCH AND DETACH FROM THE MOUNTING BRACKET OR THE KICKSTAND.
Consequence
THIS WILL ALLOW THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION AND CAUSE A CRASH.
Remedy
DEALERS WILL INSTALL A NEW KICKSTAND SPRING FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 17, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
9726
Notes
BIG DOG MOTORCYCLES, LLC
RECALL #2
Recall ID #49791 - STRUCTURE:MOTORCYCLE KICKSTAND/CENTER STAND
Recall Date NOV 02, 2004
Potential Motorcycles Affected 4457 Recall Details
Recall Date
NOV 02, 2004
Motorcycle Affected
Summary
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING ATTACHING STUD MAY BREAK OFF ALLOWING THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION.
Consequence
IF THE KICKSTAND DEPLOYS, IT COULD CAUSE A CRASH WITHOUT PRIOR WARNING.
Remedy
DEALERS WILL INSPECT AND INSTALL A NEW KICKSTAND UNIT. THE RECALL BEGAN ON DECEMBER 20, 2004. OWNERS SHOULD CONTACT BIG DOG AT 316-267-9121.
4457
Notes
RECALL #3
Recall ID #49792 - STEERING:WHEEL AND HANDLE BAR
Recall Date APR 06, 2004
Component STEERING:WHEEL AND HANDLE BAR
Potential Motorcycles Affected 2098 Recall Details
Recall Date
APR 06, 2004
Motorcycle Affected
Summary
ON CERTAIN MOTORCYCLES, A SCREW MAY BECOME LOOSE IN THE HANDLEBAR CONTROL DUE TO THE LACK OF A LOCK WASHER AND LOCTITE.
Consequence
THIS COULD CAUSE THE THROTTLE OR FRONT BRAKE CONTROL TO BIND, WHICH COULD RESULT IN A CRASH.
Remedy
DEALERS WILL INSTALL A LOCK WASHER AND LOCTITE. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-219-7006.
2098
Notes
RECALL #4
Recall ID #49793 - SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Recall Date MAR 23, 2004
Component SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Potential Motorcycles Affected 1906 Recall Details
Recall Date
MAR 23, 2004
Motorcycle Affected
Summary
ON CERTAIN MOTORCYCLES, THE PISTON IN THE REAR MASTER CYLINDER MAY HAVE BEEN IMPROPERLY SIZED, WHICH COULD CAUSE THE REAR BRAKES TO DRAG OR LOCKUP.
Consequence
THIS COULD RESULT IN A CRASH.
Remedy
DEALERS WILL REMOVE THE PISTON FROM THE REAR MASTER CYLINDER AND REPLACE IT WITH A NEW PISTON. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-267-9121.
1906
Notes
