So post 21 was before he changed out the Thunderheart module to the DYNA2001 post 25 it what happened yesterday Dec 23rd after i finish hooking up the Dyna2001. It cranks over but doesn't wanna start its not the battery & he has plenty of fuel. He was thinking maybe the timing off would that cause it
OK since the motor is now cranking strong we need to troubleshoot the
No Start issue. For a motor to run it requires
Spark, Fuel, compression and timing.
Are you fuel injected or carb? If you are fuel injected this procedure needs to be done. After disconnecting and reconnecting your battery on EFI's only. You must turn your key on, push run, you will hear the fuel pump cycle, then wait for your engine light to go off. Turn your key off, wait 15 seconds. She will be ready.
If you don't hear the pump we need to figure out why.
If it has a carburetor check to make sure your fuel petcock is set open. Take the air filter off and look inside the carb while you hit the throttle a couple of times. You should see squirts of fuel. If no squirts we move on to answer why.
If the bike passes both of these tests we will move on and troubleshoot the ignition.
