New here can you tell me what compression release that you installed I have an 03 pitbull? ThanksAlso Tom, look through the center of my rocker box. It looks like a condom. That's the top cover of my compression release's. The 2003 bikes did not come with them.the heads are tapped though. Have you added them? If not the bike is worth less. Cranking the 107 with out compression releases is just way to much on the starter. I went through 5 starters before I installed them. Now it's not an issue. The 2004 and newer the compression releases were installed.
