2003 big dog chopper primary diagram
keverett91507
Anyone have a link for an expanded diagram on a 2003 chopper primary or a 90-93 softail ? Im pretty sure they are the same. came to me in a box and zip lock bags!
roadie1389
Just do a search for 1993 softail primary it is the same. But it is pretty simple. Whats the question?
keverett91507
Just a diagram of what bolts go where would help. I'm sure I can figure it out but that would save some time
Sent from my SM-G965U using Tapatalk
roadie1389
Thanks Roadie
The Cometic 9886 has all the gaskets and locking tabs (Curtis sells it) there are 2 extra o-rings and little gasket washers that don't get used. It does NOT have a new inner primary bearing, chain tension adjuster nut or the locking tab washer, but does have the seals and the starter jackshaft seal. You will need a new jackshaft locking tab. If you have 1/4 bolt it is 33126-93 if you have the 10-32 bolt is is 33126-94, these are OEM #s. You can search these parts and get aftermarket versions.
I just put mine back together this weekend. Have fun! LOCK_TITE!!!!! The outer primary bolts are straight forward. The short ones go around the bottom and up the sides. The long ones go across the top. Not sure which drain plug you have but mine had a T-35. Good luck finding that one. I had to find a security bit set that had a T-35.
