keverett91507
Anyone have a link for an expanded diagram on a 2003 chopper primary or a 90-93 softail ? Im pretty sure they are the same. came to me in a box and zip lock bags!
The Cometic 9886 has all the gaskets and locking tabs (Curtis sells it) there are 2 extra o-rings and little gasket washers that don't get used. It does NOT have a new inner primary bearing, chain tension adjuster nut or the locking tab washer, but does have the seals and the starter jackshaft seal. You will need a new jackshaft locking tab. If you have 1/4 bolt it is 33126-93 if you have the 10-32 bolt is is 33126-94, these are OEM #s. You can search these parts and get aftermarket versions.Thanks Roadie
Sent from my SM-G965U using Tapatalk
