2002 throttle housing?
mimbler
I have a really simple question. I need to remove the switch housing on the throttle side to lube cables on my 2002 prosport and only see one screw. Removing it doesn't get the job done. Where is the other one?
thanks in advance,
Mike
Why not just use a MotionPro cable lube tool and lube from the throttle grip. Also allows the fluid to flow all the way down through the cable.
grizfish
Remove the two allen head screws holding the brake master cylinder in place. Hang the master cylinder up out of the way with something like cable ties so you don't kink the brake line.
This will reveal the other screw. Careful with the rest. It's not as difficult as it looks.
mimbler
The way I see that tool working, I would still need to disassemble the housing to get the cable out!
thanks, Mike
