2001 S&S 107 Push Rod Blocks Gasket change
cpmman
Looking to change the push rod blocks gaskets on my 03 (not a 2001 but probably ther same?) chopper..does anyone have a video(youtube?) or the service manual section I can reference to do this?
Thanks
john sachs
Thanks
No video, butttttttttttt easy enough. :eek:
1- put the first cylinder you want to change the lifterblock gaskets on top dead center(TDC) compression stroke.
2-Remove top rocker box cover.
3-Remove rocker saddle and both pushrods from that cylinder. Don't mix up pushrods (in. or ex.).
4-Remove lifter blocks, without the lifters dropping into the cam chest.
5-Replace gasket.
6-Reinstall the reverse of disassembly, being careful to let the lifters bleed down as you tighten the pushrods down.
7-When you can turn BOTH pushrods with your fingers, you can rotate the engine to TDC on the other cylinder, and replace the gasket on that lifter block. :2thumbs:
** Take your time as you're tightening the rocker saddle assembly to let the lifters bleed down, or you can do valve and guide damage. :bang:
John
Lifter block gaskets are the same for all years.
cpmman
This will be my first attempt it so maybe best to have somone experienced there that has done this successfully before..
I am a good backyard mechanic but dont want to take any chances and screw it up.
Thanks for your input...
