B bartgerbracht New Member Jul 10, 2011 #1 looking for open primary for 1999 pitbull my iner case is cracked so istead of fixing it figured would be a good time to go open.
Brew Troop Supporter Jul 10, 2011 #2 I've seen members running the older dogs with BDL and Primo open primaries. Might want to check out those sites: Belt Drives, LTD. Rivera Primo, Inc. - High-Performance Aftermarket Parts for Harley-Davidsons
B bartgerbracht New Member Jul 10, 2011 #3 i need gasket for inner and outer primary where can i find part numbers and who carries these. also will need puller for clutch.
Brew Troop Supporter Jul 10, 2011 #4 Try a Harley dealer they should have what you need for gaskets. Not sure on the part numbers you need but will be for softtails... Last edited: Jul 10, 2011
alhall88 UAW Jul 11, 2011 #6 The only thing you need to know is what the offset is prior to ordering a open primary setup.
B bartgerbracht New Member Jul 12, 2011 #7 decided to pull primary of and replace inner gasket called to order gasket and clutch puller and was told i dont need any specialty tool by my local harley dealer. never pulled a primary what if any specialty tools will i need.
