mittens
So last year, I still had the vent tube in the tank. it was not hooked to anything as the tank had a plug in it. But then it was rattling around so I removed it. No issues.
SO when its HOT out side (Alabama summer) and I am riding it, all is good. BUT when i stop, I shut the fuel petcock off (habit from dirt bikes, and cant hurt right?). Well if its super hot out, and I stop for say lunch or a best buy run.. and come back out (happened 2 time so far once lunch and once at best buy). When I open the fuel Petcock, before I start the bike and take off, its like there is pressure in the fuel tank, forcing fuel out of the carb. it leaks out the front of the carb air cleaner...... I shut off fuel...
I then start bike, and then its all ok again.. I assume pressure is building in the tank? from sitting in the sun and its just forcing fuel to dump when I open the valve under pressure? but why is there pressure building in the tank? the gas cap should vent pressure correct?
IN a related note, a few other random times... I have started the bike when hot and hot out, and if you take off instantly, it has hesitated at random like its starving for fuel.. then it catches up and its good.... related?
