Thanks, to everyone. I just opened the tool box and figured it out.
Use a 1/4 drive metric set (10mm and 11mm sockets with a 10 in. extension, new battery.
Step 1: Remove two pin bolts under the front of the seat near the small end of the gas tank
Step 2: Remove lip from mount and place padding between seat and tank
Step 2.1: Remove rear seat bolts (2 ea.) Note: Be very careful to maintain positive control of the washers as the can easily slide down into the frame well.
Step 3: Remove right bolt from the right battery cover (fiberglass / plastic) to access the battery security strap (metal). Remove the plug (black plastic oval) to reveal the second bolt under the right rear side of the seat. This plug can be removed with a very small flat tip screw driver or something similar to that size of a tip. Remove battery cover.
Step 4: Loosen battery strap and bend it back out of the way
Step 5: Remove the negative terminal first marking all wires as you remove them and then the positive with white paper tape. Right side has 5 wires and the left has 4 wires.
Step 6: Remove the battery and reassemble in reverse order.
