Do you mean the "Coil Cover" gets hot?hi i have an 07 bulldog and the ignition cover gets so hot all the time its melted the ignition 3 times in the last two yrs nowthe coils burnt out is there any info on here anywhere thats been posted you can direct me to cause i cant seem to find it ,thanks in advance
Lol no prob im not a mechanic so dont knowMy apologies, I meant along the lines of them running white or a cinnamon color.
Have you checked for any intake air leaks? Look down into the throttle body with the air filter removed and see if the gasket has sucked into the inside of the manifold.
Try running a heat range cooler sparkplug number if the sparkplugs are a gray color.
I run Champions because they have a small 5/8" hex nut size and a socket wrench can fit into the head fin area easily. I also run a heat range cooler.
Any modifications to the engine like exhaust, intake, cam, etc.?
The stock ECM/EFI module will run the bike hotter because of required EPA standards from factory. I would try sending the ECM to Wild Steed Works? and possibly get it unlocked and have the "Off road EFI box file" installed (IF YOU ARE STOCK WITH ONLY V&H BR2 PIPES) then run with it until the "service engine" LED comes on then MERGE the EFI maps and it should not only run better but probably cooler as well.
I would also connect the ECM to S&S Protune2 software and review it for any DTCs and even find out if the box is even locked or not to start with.
