06 Mastiff Rear tire
TheLaDog
Quick question before I order these tires. I currently have an 06 Mastiff with a 250 on the rear. Short and simple can I put a 260 on the rear of this bike as Metzler only makes a 240 and a 260!!! WTF huh? With the 250 I only have about a 1/2" between the belt and the tire.. Really liked the way these tires felt on another bike.. Thanks in advance..:confused:
seems like somebody posted doing this same thing in the last few days. can't remember who it was, though. sorry.
awg
I thought the Metzler tires were wider....and wouldnt fit. Not sure though. Or was it the Dunlap??
if you have .50 between the belt and the 250 and there is .60 difference between the 250 and the 260, half of that is .30 so you should still have .20 between the 260 and the belt, which is about the same gap between the 300 and the belt on the K9. just thinkin' out loud.
BigDogBro1
Made in the USA
The math works, and the tire should fit. :cheers:
Skydiver
From Pushrod243 on the Club Chopper site:
The metzler is a tiny bit smaller so it will go anywhere a 250 was mounted. Here are some tire measurments I came up with to compare big rear meats.
Tire: 240/40vr18 Metzeler
Rim rec: 8.5"
min. rim size: 8.0"
max. rim size: 9.0"
width: 9.41"
hieght: 25.78"
Tire: 260 Metzeler
Rim rec: 9.0"
min. rim size: 8.50"
max. rim size: 9.5
width: 9.8"
hieght: 25.78
Tire: 280/35vr18 Metzeler
Rim rec: 10"
min. rim size: 9.5"
max. rim size: 10.5"
width: 10.91"
hieght: 25.78"
Tire: 250/40R18 Avon
Rim rec: 9.0"
max. rim size: 9.50"
width: 10"
hieght: 25.9"
Tire: 300/35R18 Avon
Rim rec: 10.5"
min. rim size: 10"
max. rim size: 11"
width: 11.8
hieght: 26.3"
Tire: 330/30vr17 Avon
Rim rec: 12"
min. rim size: 11.5"
max. rim size: 12.5"
width: 327mm
hieght: 635mm
Tire: 240/40R18 Dunlop
Rim rec: 9.0"
width: 10.02"
hieght: 26.2"
He is off on the Dunlop 240 the info is giving is actually for the 250 tire
Inflated Width is (9.29″) for the 240 and 10.02" for the 250.
I have been through this a million times trying to figure my next tire :cheers:
oldmutt
I have a mutt with the original 250 avon on a 8.5" rim. The actual tire width is 9.5". I think the avon cobras are wider.
