05 ridgeback specs to 08/09 ridgeback
xsuittox
Anyone know if the 05 ridgeback seat has same demensions as 80/09 ridgevack ? Looking at Sterlings slimline seat, and he has 08 ridgeback, but dont see 05 slimline ridgeback.
demon dog
its definitely wider. I have both bikes and the o8 will not work. they can cut your original seat down for you.
K9 seat may come closer to fitting a '05 ridgeback.
Highly Doubt a K9 seat will match they are not nearly as long as a rigid. The shape is significantly different with a very quick pitch up in the back due to the additional fender height.
04 and 05 ridgeback seat are exactly the same even though the difference between 250 & 300. I have swapped them on another member's 05 from the forum.
was not sure, just going by the 300 width. have only had the opportunity to sit on 1 ridgeback and that has been several years ago.:cheers:
Brew
06 Ridgeback will fit your 05 Ridgeback, I'm running an 06 Ridgeback seat on my 05 Ridgeback! If any of that made sense??? :willy_nilly:
