Highly Doubt a K9 seat will match they are not nearly as long as a rigid. The shape is significantly different with a very quick pitch up in the back due to the additional fender height.K9 seat may come closer to fitting a '05 ridgeback.
was not sure, just going by the 300 width. have only had the opportunity to sit on 1 ridgeback and that has been several years ago.Highly Doubt a K9 seat will match they are not nearly as long as a rigid. The shape is significantly different with a very quick pitch up in the back due to the additional fender height.
04 and 05 ridgeback seat are exactly the same even though the difference between 250 & 300. I have swapped them on another member's 05 from the forum.
Good to know. Seems like everything is bigger on the 08 Ridgeback! Just kidding.its definitely wider. I have both bikes and the o8 will not work. they can cut your original seat down for you.
Just the rear tire...nothing to do with the size of the rider :lol:Good to know. Seems like everything is bigger on the 08 Ridgeback! Just kidding.![]()
