Working on an 04 Ridgeback. Bike belongs to a friend-of-a-friend. He had issues starting the back, and the starter got to where it would spin internally. I replaced the starter with a 2.0 KW and it cranks fine now. Battery upgraded as well.
However, the bike won't start as it has no power to the coil. If I run a jump wire from the battery to the coil it starts and runs fine.
Is there any security on this bike that would shut off the coil power? Can it be reset?
Is there any diagnostics that can be run on the ignition module? No lights stay on at the module (2 rows of yellow/red lights). The Red light on the control unit(? aluminum block about the size of a credit card) doesn't come on unless the battery to coil jumper is made.
Thanks for any insight.
