04 Chopper, removed front signals, lost left bar switches?
Moespeeds
I just put a new front end on an 04 Chopper. In the process we removed the front blinkers. I've done this before with no issues. After getting it all back together, I have no function on the left side control switches, horn, Hi/Lo, L Signal. No lights on EHC when pressing buttons. Opened up the bar switch, plug on the board is OK, Board looks OK, checked plug under tank, looks OK, no obvious shorts or grounded wires. Wiggled everything, checked for frayed wires, nothing. I just sent the owner home to get the old signals so we can plug them in just for shits and giggles. Any ideas on what else to check?
MARV
open a connection, use a grounding probe and ground one pin at a time to see if it functions. if yes then your problem is after that connection.
Moespeeds
Nevermind, my dumbass had the left side controls plugged into the front signal harness. It's all good now, Thanks!
