04 chopper front wheel
im in need of help , trying to take rim off the bike, I undone the bolt on right side, and on the left I’ve undone the pinch bolts, and I can’t seem to get the shaft to come out, is there something missing, or doing wrong, please help
knothead
Second Chance Customs
Screw the bolt back in the axle shaft about a 1/4 deep and hit it with a rubber mallet...after you get it moving you may have to find a punch or something smaller than the hole in the axle, so not to mess up the threads, and then tap it on out with a mallet
Mickmorris
Well Known Member
:agree:
Not sure what your project is & why removing the wheel but once you get it off. Replace your wheel bearings and apply anti-seize to the axle when you reinstall it. Should make it much easier next time you work on it.:cheers::chopper:
