2004 Chopper: Copy and paste from my thread on this:
Engine Idle Rattleing Noise Fixed: Loose Compensator Nut
Thanks Dakotabos for PM and hot tip on Compensator Nut on front sprocket.
After researching and watching (listening to motors idle) on a few youtube videos, I think it is a loose Compensator Nut and/or worn Compensator; as you do...
(note: I have additional noise, from the left side primary case, like a bad bearing sound "rattleing" at 800 to 950 rpm, goes away at 1000 rpm -- that has been slowly steadily getting worse; along with the chirp on decelleration).
I will try the Compensator Nut first and let you know how that turns out this weekend.
Update Saturday 4-6-2013:
**ENGINE IDLE RATTLEING WAS FIXED:
found loose Compensator Nut; removed it with about 10 ft lbs. of torque!!!!, caught it before major damage... Removed, cleaned, retightened nut with High Heat Red Loctite to 150 ft lbs. **
Thanks to "Dakotabos" and "Woodbutcher" to send me down the right path.:2thumbs:
This video also convinced me of the potential fix since my "idle" rattleing noise was not quite as bad as this Harley; [which I believe also had a loose compensator nut] (see youtube link).
