Unsprung
In the Potters hand...
Check this out, hope it works for you.Hi I too have the same problem with my new 2003 BD chopper, need a copy of a diagram. Pls pm me. Thanks
https://www.dropbox.com/sh/ng3saqa5a93gehp/AADK9gFSGaAG5oirsV17JO_Oa?dl=0
hey guys,
so i been trying to find any issues but the wires seems fine and the pins for the wires looks fine as well.
does anyone had similar problems? please help its driving me nuts..
Priceless??...there's a cost to everything..If you click on this link it will open up a lot of priceless info
http://www.bigdogbiker.com/threads/your-introduction.25016/
I have a brake light issue with my 2003 BD Chopper as well. Any info or help will be appreciated.
[/QUOTES
On the 03-04' s the wires run on the inside of the fender. More than likely the tire has rubbed the wires where it goes through the fender to the light. Repair the wires and coat them good with silicone. Use a stick to hold them up against the sides while it dries.
Look under the fender, where the wires go through to the light. If the tire has rubbed the wires, they may be shorting together.Thanks for the help. I ordered a pair of led boards for the tail lights from Big Dog thinking one had gone bad. When I installed the new one in the inop light I get a steady brake light. I'm no expert but a constant brake light on one side and a normal functioning light on the other tells me the problem is a bit deeper. Any ideas?
