02 Mastiff shifting problem
blowery
Hello All,
I posted a couple of weeks about a shifting problem,thought I had solved the problem but apparently not.shifts 1-3 with no problem but dosent want to shift to 4th,5th and 6th.I,ve adjusted the clutch,changed all fluids,but unsure of what to do next,I noticed this morning with the bike in gear and the clutch engaged I cannot roll the bike,is this normal?it dosent seem to be trying to creep while sitting at red lights and such,but it dosent roll freely either.I can make it shift into the higher gears by pulling on it several times and eventually it will shift,yet at other times it shifts just fine,no problems down shifting ever,I haven't ridden it since adjusting the clutch,but based on what im seeing on the jack there dosent appear to be any improvement,any help will be greatly appreciated.
blowery
Thanks kaptin,,I did notice the primary chain seems to be pretty loose,could that be the problem,never attempted adjustment before,but it dosent appear to be that complicated,even if it dosent solve the issue it needs to be done anyway.BTW I will be ordering a set of shocks and an airfilter from wildsteedworx later this evening,gotta wait on the Mrs.to get home since I no nothing about Pay pal
