Needing a used speedometer connector, and rip harness or used ehc
Nwhicks21
I had a damaged carrier bearing and my starter wouldn't engage due to binding, ended up shorting out my harness connecting to the speedometer and possible damaged harness elsewhere and ehc. Since I have no power to the speedo im assuming the ehc fried, I cannot afford 800 for new ehc or rip kit can anyone steer me to a cheaper solution or some used parts please? I have tried and tried contacting wild steel works with no response, I just wanna get my bike going again
Nwhicks21
Wild steel works won’t respond to me I’ve been messaging them for weeks, and I think I got ahold of hdm and they didn’t have either one the carrier or the wiring I’m needing
Nwhicks21
Nope they don’t have it either. Neither does dead one customs. They have a new replacement esc for 1300 but I can’t afford half that
kickstart
I also have a 05 Bulldog and I have a used EHC that was checked out by WSW that I traded him (Curtis) for a new Wire Plus unit I decided not to use.
I think I have about $300 in that.
Messaging wont work. Give Curtis a phone call. Better chance of the one man show answering.
kickstart
I will give you 300 if it works
All I can tell you is it came from WSW and he said it was good. If Curtis says it's good it is. I have no way to check it . You need to talk to Curtis about all your bikes issues and then decide how you are going to proceed.
Coolbreezin
Me again. Guess what Im going to say? :oldlaugh:
Rewire the entire bike and remove the brain (its retarded, thank you Sheldon Coleman).
I had Chopper City in south Jacksonville, FL do mine, $1500. Absolutely no issues since that day years ago. I have two fuses and thats it. My tach is wiggin out right now. Guess all the places Ill check...the tach!
Im sorry everyone has so many unnecessary issues with their bikes. But the ehc's of our bikes are the appendix of our bodies.
Good luck. I hope youre out :moped: soon.
dtmmil
Do you have turn signals? If so how are they wired do you know?
