cvegmond
Buy a Wire Plus
The EHC is giving up. The tiny switches, relays inside the module go out differently for different BDM onwers.
Sorry, my fellw K-9 owner...your time has come. Check my garage for a good wiring diagram of the Wire Plus system. By the way, the BDM speedometer and ignition systems are crappy too, so I replaced them as well.
I ride my K-9 to work and don't have anymore electrical issues...thanks to great aftermarket parts.
Cor.
Your battery is fine. Your connections are fine or else the bike would never start. The ambient temperature nor the phases of moon have anything to do with the bike acting bizzare.Ok, the outside temperature dropped to 45F this evening and the bike would not start. Turned the key and the emergency flashers started flashing - absolutely nothing else worked. No tach lights, no fuel pump whine, no starter engage, no horn, no head light, etc. The emergency flashers continue and can't be stopped unless I turn the key off. This is crazy!!!!!!!
If I happen to turn the key on and get No emergency hazard flashers, every thing works great - tach lights up, fuel pump whines, starter engages, and the engine turns over/starts like a champ!! This tells me the battery and wiring connections are fine. SOMETHING IS TELLING THE EHC TO FLASH THE EMERGENCY FLASHERS AND NOT ENERGIZE THE "POWER UP" CIRCUIT.
Still scratching my head?? :bang::bang::bang:
Cor.
