06 pitbull rear fender
TYPE-II
I have been going through my bike and checking the nuts and bolts on it and came across a bracket that the rear fender is secured to the frame. It looks like a chrome L-bracket and it’s cracked. Does anyone know what it’s called so I can get a replacement? If you need pics, I’ll take some tomorrow and post them here. I just don’t know what it is called or where to pick one up.
Is it a fender strut? Connects the fender assembly to the frame? Pics would help.
Hdm or Wildsteedworx will be good parts sources.
awg
I just looked at mine. I have a chrome 90 degree I guess you would call it a brace or bracket that bolts to the fender and it looks like a flat bracket above the oil tank. If it's the chrome piece you can make one out of steel I would think. The other part, I don't know. I guess you can do the same. Or see if someone on the forum has one laying around. Seems odd it would crack. It's a pretty thick piece.
TYPE-II
I believe that’s what it is that you’re talking about. I’ll take a pic once I get home.
TYPE-II
Forgot to get pics on mine, but it’s the same part. Mine is cracked on the bottom part of the L-bracket on either side of the bolt hole.
TYPE-II
You should be able to make one. If you can't find the original. Not much help, but that's all I got.
I figured I would be able to make one. Doesn’t look like a difficult thing to make. Thanks though.
