Appreciate your comments. I think I've found the problem (Me)! In order to really test the movement of the swingarm I removed the back wheel, fender, and Shocks. I had just put new Shocks on about two months ago. When I went th remove the front two bolts, both had backed out significantly! When I put the new Shocks in I had sprayed brake cleaner in the bolt holes trying to get all the previous loctite out. I think that cleaner dissolved the new loctite I put on. So, my thoughts are that without the Shocks stability at the bottom of the swingarm it allowed the back end to twist slightly and push the axle rearward...opposite the drive pully. I know that on the test drive after first installing the shocks everything was fine. It was a couple of rides later that I began experiencing problems. I couldn't understand how the axle could move either if it was tightly secured by the setscrews. If you think about it for a moment, if you twist the swingarm towards the drive pully side, that changes the geometry of the entire back end in relation to the transmission drive gear. So, that would seem to be what caused the axle to move rearward on the left side, opposite the drive pully. I also noticed that my axle spacers could be rotated quite easily with the axle torqued to 65 ft lbs. So I ordered new ones, probably need a 1/64 axle shim if I can find one. I'm thinking about using one of the old spacers...recut one to use on the left side making it 1/64 wider.
So, I've just been in an auto accident...got rear ended a few days ago and I'm banged up a little. It will be at least a couple of weeks before I can work on the bike.
As usual, I cannot tell you guys how much I appreciate the great response I get from all my posts. The FORUM is always the first place I go to for any problems. Thanks
