Mastiff Rider64
I'm already thinking of next winters project. I'm thinking of taking my 2009 Bulldog Bagger from EFi to Carb. But not sure what all I would have to do because of the VFI and ECH and installing a ignition module. I know I would need a new intake manifold, gaskets, I'd have to install a petcock plate in the gas tank, gas line, I'd have to install a Carb. But what all would be needed to do this? I searched for a forum that I once saw on here of someone discussing doing this but I couldn't find it.
The reason for this is because I continue to have issues with the set up on the bagger, check engine light coming on and going into limp mode, but checking codes and no codes, I crank the bike the engine light is off, having to have it dyno tuned several times because it doesn't seem to keep the crank and idle settings, spitting and sputtering after cranking sometimes others times I sometimes crank the bike and its rough idling and when I give it gas it revs up to 3500 RPM and just stays there till I cut the bike off, then the next time I crank the bike it may start just fine, seems that sometimes I'm still running extremely hot, with dual oil coolers on an 80 degree day in red light to red light traffic. I got in touch with S&S and they say they can get me a basic tune, but can't say that will fix the problems I'm having.
The local custom motorcycle shop here that was a bigdog service center up till 2011 that has been thru this bike over and over has run out of ideas. And the mechanic there is S&S certified and protune certified, but he even admits that he doesn't use protune enough to know all the in and outs of the software and he says that S&S has discontinued continuous education for mechanics on the software.
If anyone has any ideas I'd appreciate them greatly.
Too expensive and problematic to change over to a carb system. Keep Troubleshooting!
