Good morning brothers, well I did test like Mr. Wright suggested and found that the battery is not being charged and I didn't get any readings from the magneto. I'm guessing I need the magneto kit and maybe go ahead and change out the ECM or kCM didn't know which one I need. Its 06 Mastiff carburetor. Last thing, where can I get quality parts. Thanks in advance you all
Thats why we are here. Jmo, if she started and ran good your ecm may be just fine? Get the charging system replaced and see where you at.Great advice Mickmorris. I've ordered the stator and regulator need to look into the ecm tomorrow. Again, I thank you all for taking the time to help with my girl's issues
Not sure why you are hell bent on replacing your EHC? The charging system and EHC are not related. A preemptive strike on the EHC is expensive and also really not necessary unless you have failures.Great advice Mickmorris. I've ordered the stator and regulator need to look into the ecm tomorrow. Again, I thank you all for taking the time to help with my girl's issues
