Yep. I know its been down on the right side but I dont think it was hard enough to torque the neck? Could be a frame defect? Ima break out the laser n see what I can find. Aint gonna lie, Im kinda scared, after some of the other issues Ive run into.I would check alignment of rear to front tire just for the hell of it.
Be brave young manYep. I know its been down on the right side but I dont think it was hard enough to torque the neck? Could be a frame defect? Ima break out the laser n see what I can find. Aint gonna lie, Im kinda scared, after some of the other issues Ive run into.![]()
I used my usual method of lining up the new rear. I center punch the axle bolts an use calipers from there to the frame. I try to keep it within .010-.020 side to side, but I gotta figure where I went wrong? Swingarm may off a tic? I hope its just my incompetence...?Found the same thing on my last front Shinko. Pretty sure it was an alignment error on my part as the rear (Shinko) was worn in a similar pattern (off center). Re-aligned the darn thing and am checking out regularly now. Still buying Shinkos because I couldn’t find reasonably priced Avons.
Please let us know what you find.
Hahaha....it was fairly fresh when I changed the rear. That was just before Dave's in Sept. I havent put that many miles on it...since I got it maybe 2500? I woulda figured road crown would be wear on the left side? We aint got many RH turns here either.....ride straight, stop, turn right. Kansas kinda straight n flat where I live. Only right handers are roundabouts and I only do two laps on them!Always get more wear on the right side due to road crown and RH turns are longer.
Most don’t notice because they would have changed that tire 100,000 miles ago
You must be somewhere that drives on the left side of the road.Always get more wear on the right side due to road crown and RH turns are longer.
Nope. Seems to track normally.Does the bike pull to the right while going straight down a flat road.?
Exactly!That makes sense—thanks for the update, Hman. How did you check that? Put it on a center lift and lift the front tire to check for play?
Good time to check the fall away after assemblyExactly!
